跳转到主内容
Alcatel Pop 4 Plus Front Camera Replacement
你所需要的
  1. Alcatel Pop 4 Plus Front Camera Replacement, Battery: 步骤 1 中的图像 1,2 Alcatel Pop 4 Plus Front Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Front Camera Replacement: 步骤 2 中的图像 1,2 Alcatel Pop 4 Plus Front Camera Replacement: 步骤 2 中的图像 2,2
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Front Camera Replacement: 步骤 3 中的图像 1,1
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Front Camera Replacement: 步骤 4 中的图像 1,2 Alcatel Pop 4 Plus Front Camera Replacement: 步骤 4 中的图像 2,2
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: 步骤 5 中的图像 1,2 Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
    • Slide the ribbon cable out of the socket.
  6. Alcatel Pop 4 Plus Front Camera Replacement: 步骤 6 中的图像 1,2 Alcatel Pop 4 Plus Front Camera Replacement: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger to disconnect the ribbon cable.
  7. Alcatel Pop 4 Plus Front Camera Replacement: 步骤 7 中的图像 1,2 Alcatel Pop 4 Plus Front Camera Replacement: 步骤 7 中的图像 2,2
    • Using the flat end of the spudger to disconnect the ribbon cable.
  8. Alcatel Pop 4 Plus Front Camera Replacement: 步骤 8 中的图像 1,2 Alcatel Pop 4 Plus Front Camera Replacement: 步骤 8 中的图像 2,2
    • Using the flat end of the spudger, disconnect the camera from the motherboard.
  9. Alcatel Pop 4 Plus Front Camera Replacement: 步骤 9 中的图像 1,1
    • Use the flat end of the spudger to pry off the motherboard.
  10. Alcatel Pop 4 Plus Front Camera Replacement, Front Camera: 步骤 10 中的图像 1,1
    • Disconnect the camera from the motherboard using the flattened of a spudger.
结论
peter achanccaray
于01/25/18注册
123 声望
撰写一个指南
团队
USF Tampa, Team S20-G6, Passmore Spring 2018 USF Tampa, Team S20-G6, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G6
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 306
