跳转到主内容
Alcatel One Touch Evolve 2 Front Speaker Replacement
你所需要的
  1. Alcatel One Touch Evolve 2 Front Speaker Replacement, Back Frame: 步骤 1 中的图像 1,3 Alcatel One Touch Evolve 2 Front Speaker Replacement, Back Frame: 步骤 1 中的图像 2,3 Alcatel One Touch Evolve 2 Front Speaker Replacement, Back Frame: 步骤 1 中的图像 3,3
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Alcatel One Touch Evolve 2 Front Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. Alcatel One Touch Evolve 2 Front Speaker Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  4. Alcatel One Touch Evolve 2 Front Speaker Replacement: 步骤 4 中的图像 1,3 Alcatel One Touch Evolve 2 Front Speaker Replacement: 步骤 4 中的图像 2,3 Alcatel One Touch Evolve 2 Front Speaker Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  5. Alcatel One Touch Evolve 2 Front Speaker Replacement: 步骤 5 中的图像 1,2 Alcatel One Touch Evolve 2 Front Speaker Replacement: 步骤 5 中的图像 2,2
    • Pull the rear frame off with your hands.
  6. Alcatel One Touch Evolve 2 Front Speaker Replacement, Main Circuit Board: 步骤 6 中的图像 1,2 Alcatel One Touch Evolve 2 Front Speaker Replacement, Main Circuit Board: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to pop the speaker press-fit connector free.
    • Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
  7. Alcatel One Touch Evolve 2 Front Speaker Replacement: 步骤 7 中的图像 1,1
    • Use a plastic opening tool to lift the front camera press-fit connector free.
  8. Alcatel One Touch Evolve 2 Front Speaker Replacement: 步骤 8 中的图像 1,1
    • Insert one of the plastic opening tools into any side of the main circuit board and gently pry it loose from the front cover. Repeat the process all around the circuit board.
  9. Alcatel One Touch Evolve 2 Front Speaker Replacement: 步骤 9 中的图像 1,1
    • Detach the main circuit board from the front cover.
  10. Alcatel One Touch Evolve 2 Front Speaker Replacement, Front Speaker: 步骤 10 中的图像 1,2 Alcatel One Touch Evolve 2 Front Speaker Replacement, Front Speaker: 步骤 10 中的图像 2,2
    • Use a spudger to pry out the speaker from the front panel using the prongs on the speaker.
结论
Akira Nakaza
于11/08/17注册
427 声望
创作了3篇指南
团队
IUPUI, Team S5-G5, Baechle Fall 2017 IUPUI, Team S5-G5, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S5G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 243
