跳转到主内容
Alcatel Fierce 4 Front-Facing Camera Replacement
你所需要的
  1. Alcatel Fierce 4 Front-Facing Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Using a plastic opening tool, pry the back cover off of the phone.
  2. Alcatel Fierce 4 Front-Facing Camera Replacement: 步骤 2 中的图像 1,2 Alcatel Fierce 4 Front-Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the seventeen Phillips #000 screws from the mid-frame.
  3. Alcatel Fierce 4 Front-Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
  4. Alcatel Fierce 4 Front-Facing Camera Replacement: 步骤 4 中的图像 1,2 Alcatel Fierce 4 Front-Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to disconnect all of the cables on the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
  5. Alcatel Fierce 4 Front-Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the motherboard from the phone.
  6. Alcatel Fierce 4 Front-Facing Camera Replacement: 步骤 6 中的图像 1,1
    • Carefully pry up the battery with a plastic opening tool, or your hands.
  7. Alcatel Fierce 4 Front-Facing Camera Replacement, Front-Facing Camera: 步骤 7 中的图像 1,3 Alcatel Fierce 4 Front-Facing Camera Replacement, Front-Facing Camera: 步骤 7 中的图像 2,3 Alcatel Fierce 4 Front-Facing Camera Replacement, Front-Facing Camera: 步骤 7 中的图像 3,3
    • Use a plastic opening tool to pry up the camera connector from the motherboard.
    • Remove the camera.
结论
Rawan
于02/22/18注册
650 声望
创作了4篇指南
团队
USF Tampa, Team S1-G2, Cagle Spring 2018 USF Tampa, Team S1-G2, Cagle Spring 2018 的会员
USFT-CAGLE-S18S1G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 187
