跳转到主内容
Air Hog Smash Bots Radio Receiver Replacement
你所需要的
  1. Air Hog Smash Bots Radio Receiver Replacement, Batteries: 步骤 1 中的图像 1,1
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Air Hog Smash Bots Radio Receiver Replacement: 步骤 2 中的图像 1,1
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Air Hog Smash Bots Radio Receiver Replacement: 步骤 3 中的图像 1,1
    • Remove the 3 AAA batteries.
  4. Air Hog Smash Bots Radio Receiver Replacement, External Casing: 步骤 4 中的图像 1,2 Air Hog Smash Bots Radio Receiver Replacement, External Casing: 步骤 4 中的图像 2,2
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Air Hog Smash Bots Radio Receiver Replacement: 步骤 5 中的图像 1,2 Air Hog Smash Bots Radio Receiver Replacement: 步骤 5 中的图像 2,2
    • Remove the upper armor of the Smash Bot.
  6. Air Hog Smash Bots Radio Receiver Replacement: 步骤 6 中的图像 1,1
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Air Hog Smash Bots Radio Receiver Replacement: 步骤 7 中的图像 1,1
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Air Hog Smash Bots Radio Receiver Replacement: 步骤 8 中的图像 1,2 Air Hog Smash Bots Radio Receiver Replacement: 步骤 8 中的图像 2,2
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: 步骤 9 中的图像 1,2 Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: 步骤 9 中的图像 2,2
    • Use the Phillips 0 screwdriver to remove two 4.75mm screws.
  10. Air Hog Smash Bots Radio Receiver Replacement: 步骤 10 中的图像 1,2 Air Hog Smash Bots Radio Receiver Replacement: 步骤 10 中的图像 2,2
    • Use the soldering workstation to remove the five wires. Directions on how to solder can be found here.
结论
另外一个人完成了本指南。
Brittany Frecker
于02/08/16注册
542 声望
创作了4篇指南
团队
IUPUI, Team 1-1, Baechle Spring 2016 IUPUI, Team 1-1, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S1G1
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 296
