跳转到主内容
加入维修社区 - 创建账户
Afterglow Wireless PS3 Controller Vibration Motor Replacement
你所需要的
  1. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: 步骤 1 中的图像 1,2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: 步骤 2 中的图像 1,2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: 步骤 2 中的图像 2,2
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Vibration Motor Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Vibration Motor Replacement: 步骤 4 中的图像 1,3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: 步骤 4 中的图像 2,3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: 步骤 4 中的图像 3,3
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so that the vibration motor wire connections are accessible.
  5. Afterglow Wireless PS3 Controller Vibration Motor Replacement: 步骤 5 中的图像 1,2 Afterglow Wireless PS3 Controller Vibration Motor Replacement: 步骤 5 中的图像 2,2
    • Pull both vibration motors straight up from their holding place.
  6. Afterglow Wireless PS3 Controller Vibration Motor Replacement: 步骤 6 中的图像 1,1
    • Use the soldering tool to heat the solder connecting the red and black vibration motor wires to the motherboard to detach the vibration motors.
    • Use this guide for further details on how to solder.
结论
Natalie Cox
于02/17/17注册
207 声望
创作了2篇指南
团队
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G5
4 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 57
总计 1,392
