跳转到主内容
Afterglow Wireless PS3 Controller Motherboard Replacement
你所需要的
  1. Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Motherboard Replacement, Motherboard: 步骤 2 中的图像 1,1
    • Desolder the battery connection from the motherboard.
    • Use this guide for more information on soldering.
  3. Afterglow Wireless PS3 Controller Motherboard Replacement: 步骤 3 中的图像 1,2 Afterglow Wireless PS3 Controller Motherboard Replacement: 步骤 3 中的图像 2,2
    • Unscrew the two 9mm Phillips #0 screws that secure the motherboard to the controller front plate.
  4. Afterglow Wireless PS3 Controller Motherboard Replacement: 步骤 4 中的图像 1,2 Afterglow Wireless PS3 Controller Motherboard Replacement: 步骤 4 中的图像 2,2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The bottons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  5. Afterglow Wireless PS3 Controller Motherboard Replacement: 步骤 5 中的图像 1,2 Afterglow Wireless PS3 Controller Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove two button padding from the back of motherboard.
  6. Afterglow Wireless PS3 Controller Motherboard Replacement: 步骤 6 中的图像 1,2 Afterglow Wireless PS3 Controller Motherboard Replacement: 步骤 6 中的图像 2,2
    • Desolder the four button connections from the motherboard.
    • Desolder the joy stick connections located on the front.
结论
Natalie Cox
于02/17/17注册
207 声望
创作了2篇指南
团队
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G5
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 45
总计 1,073
