跳转到主内容
加入维修社区 - 创建账户
Afterglow Wireless PS3 Controller Battery Replacement
你所需要的
  1. Afterglow Wireless PS3 Controller Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Afterglow Wireless PS3 Controller Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Battery Replacement, Battery: 步骤 2 中的图像 1,1
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Battery Replacement: 步骤 3 中的图像 1,1
    • Use the soldering tool to heat the solder connecting the battery wires to the motherboard.
    • The soldering gun will loosen the bonds of the solder allowing the wires to be detached. Use this guide for further details on how to solder.
结论
Aj Coello
于02/17/17注册
1,164 声望
创作了6篇指南
团队
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G5
4 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 30
过去 30 天: 102
总计 4,061
