简介
Use this guide to change the battery on your Acer Predator Helios 300 (2020).
Model Number: PH3-15-53
The laptop battery is essential to provide portable usage since it keeps the laptop powered on.
You might want to replace your laptop battery if it is slow to charge or overheating. If the laptop is not charging, you might want to check if the power adapter for the battery is plugged in correctly before you replace the battery.
Before you begin the repair, power off your laptop and unplug the device from the charger.
你所需要的
For optimal performance, after completing this guide, calibrate your newly installed battery.
8等其他人完成本指南。
一条评论
You're awesome, full stop. Thanks for this ridiculously easy to follow guide. Publishing guides should be your job.
Jeff Noble - 回复
