跳转到主内容
Acer Chromebook CB5-132T-C8ZW Battery Replacement
你所需要的
  1. Acer Chromebook CB5-132T-C8ZW Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove eleven 7.2 mm screws from the bottom of the Chromebook using a JIS #1 screwdriver.
  2. Acer Chromebook CB5-132T-C8ZW Battery Replacement: 步骤 2 中的图像 1,2 Acer Chromebook CB5-132T-C8ZW Battery Replacement: 步骤 2 中的图像 2,2
    • Insert and slightly twist a plastic opening tool to separate and remove the backing of the Chromebook from the body.
    • Do not immediately remove the back from the laptop. The power strip keeps the backing attached to the rest of the laptop. Gently lift backing from the power button side and set next to the body of the laptop.
  3. Acer Chromebook CB5-132T-C8ZW Battery Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB5-132T-C8ZW Battery Replacement: 步骤 3 中的图像 2,2
    • Remove two 4.6 mm JIS # screws at each end of the battery.
  4. Acer Chromebook CB5-132T-C8ZW Battery Replacement: 步骤 4 中的图像 1,3 Acer Chromebook CB5-132T-C8ZW Battery Replacement: 步骤 4 中的图像 2,3 Acer Chromebook CB5-132T-C8ZW Battery Replacement: 步骤 4 中的图像 3,3
    • Carefully pull out the ribbon cable attached to the motherboard that runs wires to the battery.
    • Remove the battery.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 7
总计 366
