跳转到主内容
Acer Chromebook CB3-111-C670 Battery Replacement
你所需要的
  1. Acer Chromebook CB3-111-C670 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Be sure to have completely shut down the device before attempting to open it.
    • Remove the twelve Phillips #00 screws.
  2. Acer Chromebook CB3-111-C670 Battery Replacement: 步骤 2 中的图像 1,1
    • Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Carefully open the case to the left to avoid ripping the interior ribbon cable.
  3. Acer Chromebook CB3-111-C670 Battery Replacement: 步骤 3 中的图像 1,1
    • Pull the battery connector cable towards the battery to disconnect it.
  4. Acer Chromebook CB3-111-C670 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery.
结论
6等其他人完成本指南。
Tony
于01/20/16注册
459 声望
创作了2篇指南
团队
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G5
3 名成员
创作了8篇指南
一条评论
Off topic and everything but how can i fix the audio jack? My audio jack is so worn it wont play sound
Daichi Potato - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 4,075
