跳转到主内容
Acer Chromebook 15 CB5-571-C09S Fan Replacement
你所需要的
  1. Acer Chromebook 15 CB5-571-C09S Fan Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 2 中的图像 1,2 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 2 中的图像 2,2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 3 中的图像 1,2 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 4 中的图像 1,2 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 4 中的图像 2,2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Fan Replacement, Fan: 步骤 5 中的图像 1,3 Acer Chromebook 15 CB5-571-C09S Fan Replacement, Fan: 步骤 5 中的图像 2,3 Acer Chromebook 15 CB5-571-C09S Fan Replacement, Fan: 步骤 5 中的图像 3,3
    • The fan is located at the top of the device enclosed by a grey plastic covering and is attached to the motherboard by a piece of brass colored metal.
    • Unscrew the four 3 mm PH00 Phillips screws located on the corner edges of the brass colored piece of metal.
  6. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 6 中的图像 1,2 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 6 中的图像 2,2
    • Unscrew the two 4 mm PH00 Phillips head screws on either side of the the fan.
    • Be aware that these screw are enclosed by small pieces of plastic and are not to be removed from the fan cover.
  7. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 7 中的图像 1,2 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 7 中的图像 2,2
    • Disconnect the fan connector from the motherboard using two plastic opening tools.
    • The fan connector is the white "plug" that connects the battery to the motherboard with yellow, white, red and black wires attached to it.
  8. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 8 中的图像 1,2 Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 8 中的图像 2,2
    • Carefully unwrap the black and white wires from around the fan cover.
    • Be careful not to remove the wires from the Intel Dual Band Wireless-AC 7260 ports located just beneath the fan connector.
  9. Acer Chromebook 15 CB5-571-C09S Fan Replacement: 步骤 9 中的图像 1,1
    • Grab the fan by its cover and the brass colored piece of metal and carefully lift up and pull out the fan from the device.
结论
另外一个人完成了本指南。
Sakiynah Howard
于10/17/17注册
1,000 声望
创作了6篇指南
团队
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G3
3 名成员
创作了12篇指南
一条评论
Thanks for the guide. I was able to successfully replace my fan using it. I would like to point out a couple of things:
1. 10 minutes is not a realistic completion time for this guide.
2. Disconnecting the fan plug is challenging. It might have been easier with a small pair of pliers.
3. Since this guide involves dis/re-connecting the thermal interface between the processor and heat sink, you should be prepared to properly clean both surfaces and re-apply new thermal compound. There is an excellent guide on applying thermal compound here:
如何涂散热膏
Tristan Mackey - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 348
