跳转到主内容
Acer Chromebook 14 CB3-431-C3WS Speaker Replacement
你所需要的
  1. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Back Cover: 步骤 1 中的图像 1,3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Back Cover: 步骤 1 中的图像 2,3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: 步骤 3 中的图像 1,2 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: 步骤 3 中的图像 2,2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: 步骤 4 中的图像 1,1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Battery: 步骤 5 中的图像 1,3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Battery: 步骤 5 中的图像 2,3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Battery: 步骤 5 中的图像 3,3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: 步骤 6 中的图像 1,2 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: 步骤 6 中的图像 2,2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: 步骤 7 中的图像 1,1
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Speaker: 步骤 8 中的图像 1,1
    • Remove the four 4mm JIS #0 screws that hold the speakers in place.
  9. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: 步骤 9 中的图像 1,1
    • Disconnect the clip that connects the speaker wires to the daughterboard.
  10. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: 步骤 10 中的图像 1,1
    • Lift the speakers from the frame, making sure to carefully unwind the wires connecting the speakers.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 320
