跳转到主内容
Acer Chromebook 14 CB3-431-C3WS Screen Replacement
你所需要的
  1. Acer Chromebook 14 CB3-431-C3WS Screen Replacement, Screen: 步骤 1 中的图像 1,2 Acer Chromebook 14 CB3-431-C3WS Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Using an iFixit opening pick, pop off the bezel from around the screen, beginning on one side and continuing around the whole screen.
    • Remove the barrier from the front of the screen.
  2. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: 步骤 2 中的图像 1,1
    • Starting in the top right of the screen, remove the six 4mm JIS #0 screws that secure the computer screen to the top.
    • There will be two sets of two screws on the top, one screw on each side of the bottom of the screen.
  3. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the screen down, and lay it flat against the keyboard.
  4. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: 步骤 4 中的图像 1,1
    • Disconnect the input connector from the screen.
  5. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the screen.
结论
2等其他人完成本指南。
3条评论
I have horizontal lines that appear for a split second on my screen at random times . Pushing the screen makes the lines appear also. I think I might have dropped my laptop , which may have caused this. Would changing the screen fix this?
aarondhesi - 回复
Hi, i have the same problem. did it work for you?
Another Backup -
It should! When we looked into troubleshooting this, changing the screen can help with the lines you're seeing.
Samantha Postma - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 3,476
