跳转到主内容
Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement
你所需要的
  1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 3 中的图像 1,2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 3 中的图像 2,2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: 步骤 5 中的图像 1,3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: 步骤 5 中的图像 2,3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: 步骤 5 中的图像 3,3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 6 中的图像 1,2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 6 中的图像 2,2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 7 中的图像 1,1
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Disconnect the LCD cable from the motherboard by removing the tape on the LCD connector, then gently pulling out the ribbon cable.
  9. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 9 中的图像 1,3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 9 中的图像 2,3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 9 中的图像 3,3
    • Disconnect the LCD cable from the motherboard by gently pulling on the cable.
  10. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 10 中的图像 1,1
    • Disconnect the trackpad by pulling on the trackpad connector cable.
  11. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 11 中的图像 1,2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 11 中的图像 2,2
    • Disconnect the daughterboard from the motherboard by gently removing the daughterboard cable from the motherboard connector.
  12. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 12 中的图像 1,2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 12 中的图像 2,2
    • Remove the electrical tape covering the screw that holds the Wi-Fi card in place.
    • Remove the single 4mm JIS #0 screw that holds the Wi-Fi card in place.
  13. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the seven 4mm JIS #0 screws that hold the motherboard in place.
  14. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: 步骤 14 中的图像 1,1
    • Gently remove the motherboard.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 8
过去 30 天: 25
总计 1,877
