跳转到主内容
Acer Aspire V5-571P-6815 Keyboard Replacement
你所需要的
  1. Acer Aspire V5-571P-6815 Keyboard  Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the two 7mm Phillips #00 screws from the bottom of the laptop.
  2. Acer Aspire V5-571P-6815 Keyboard  Replacement: 步骤 2 中的图像 1,3 Acer Aspire V5-571P-6815 Keyboard  Replacement: 步骤 2 中的图像 2,3 Acer Aspire V5-571P-6815 Keyboard  Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool underneath the keyboard and pry upwards.
    • Slide the plastic opening tool around the perimeter to free the keyboard.
    • Flip the keyboard over and onto the palm rest.
  3. Acer Aspire V5-571P-6815 Keyboard  Replacement: 步骤 3 中的图像 1,3 Acer Aspire V5-571P-6815 Keyboard  Replacement: 步骤 3 中的图像 2,3 Acer Aspire V5-571P-6815 Keyboard  Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    • Remove the keyboard from the laptop.
结论
2等其他人完成本指南。
Jmarqu2
于04/12/18注册
133 声望
撰写一个指南
团队
UW Tacoma, Team S1-G4, Liner Spring 2018 UW Tacoma, Team S1-G4, Liner Spring 2018 的会员
UWT-LINER-S18S1G4
5 名成员
创作了8篇指南
2条评论
This guide is wrong. All keyboard sold online come without the frame and replacing the keyboard is actually a very tedious process as it’s attached with melt plastic.
Sergey Ratakhin - 回复
Thank you! All this guide shows is how to take out and put in the exact same keyboard, which doesn't seem to be available anywhere. I've been looking for an exact replacement and haven't been able to find one. The original keyboard has the frame with the power button. NONE of the replacement options has ANYTHING with the power button.
Raul - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 12
总计 3,292
