跳转到主内容
Acer Aspire V5-571P-6815 Charging Port Replacement
你所需要的
  1. Acer Aspire V5-571P-6815 Charging Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer and unplug all power.
  2. Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 2 中的图像 1,2 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 2 中的图像 2,2
    • Slide the locking latch to the right and hold while pulling the battery out with your other hand.
  3. Acer Aspire V5-571P-6815 Charging Port Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the two 7mm Phillips #00 screws from the bottom of the laptop.
  4. Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 4 中的图像 1,3 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 4 中的图像 2,3 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic opening tool underneath the keyboard and pry upwards.
    • Slide the plastic opening tool around the perimeter to free the keyboard.
    • Flip the keyboard over and onto the palm rest.
  5. Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 5 中的图像 1,3 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 5 中的图像 2,3 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    • Remove the keyboard from the laptop.
  6. Acer Aspire V5-571P-6815 Charging Port Replacement, Charging Port: 步骤 6 中的图像 1,1
    • Remove the six 6mm Phillips #0 screws from underneath the keyboard.
  7. Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 7 中的图像 1,1
    • Remove the sixteen 6mm Phillips #0 screws from the bottom cover.
  8. Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 8 中的图像 1,3 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 8 中的图像 2,3 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 8 中的图像 3,3
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
    • Pull the ribbon cable from the socket.
  9. Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 9 中的图像 1,2 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 9 中的图像 2,2
  10. Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 10 中的图像 1,3 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 10 中的图像 2,3 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 10 中的图像 3,3
    • Use a plastic opening tool to pry up the palm rest from the laptop body.
    • Remove the palm rest from the laptop.
  11. Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 11 中的图像 1,2 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 11 中的图像 2,2
    • Disconnect the charging port cable from the motherboard.
    • You might have to remove some electrical tape that is in the way.
  12. Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 12 中的图像 1,3 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 12 中的图像 2,3 Acer Aspire V5-571P-6815 Charging Port Replacement: 步骤 12 中的图像 3,3
    • Lift the charging port up and out of the laptop.
结论
Follow the steps in reverse with a new cable.
另外一个人完成了本指南。
Gordon Tran
于04/12/18注册
225 声望
撰写一个指南
团队
UW Tacoma, Team S1-G4, Liner Spring 2018 UW Tacoma, Team S1-G4, Liner Spring 2018 的会员
UWT-LINER-S18S1G4
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 24
总计 5,508
