跳转到主内容
Acer Aspire V5-571-6889 Display Assembly Replacement
你所需要的
  1. Acer Aspire V5-571-6889 Display Assembly Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Display Assembly Replacement: 步骤 4 中的图像 1,1
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Display Assembly Replacement, Remove Upper Cover: 步骤 5 中的图像 1,1
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Display Assembly Replacement: 步骤 6 中的图像 1,1
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
  7. Acer Aspire V5-571-6889 Display Assembly Replacement, Display Assembly: 步骤 7 中的图像 1,1
    • Remove the top left screw that is connecting the display assembly and the body of the laptop.
    • Remove the 2.5 mm by 5 mm screw by using #0 Phillips head screw driver.
  8. Acer Aspire V5-571-6889 Display Assembly Replacement: 步骤 8 中的图像 1,1
    • Using a #0 Phillips screw driver, remove the other 2.5 mm by 5 mm phillips screw that holds the display assembly.
  9. Acer Aspire V5-571-6889 Display Assembly Replacement: 步骤 9 中的图像 1,1
    • Gently disconnect the display cable connector between the display assembly and the motherboard.
  10. Acer Aspire V5-571-6889 Display Assembly Replacement: 步骤 10 中的图像 1,1
    • Remove the tape holding down the display cable that connects it to the motherboard.
  11. Acer Aspire V5-571-6889 Display Assembly Replacement: 步骤 11 中的图像 1,1
    • Disconnect the tape that is holding the white antenna cable to the motherboard.
  12. Acer Aspire V5-571-6889 Display Assembly Replacement: 步骤 12 中的图像 1,1
    • Take the display assembly off and replace it with a new one.
结论
另外一个人完成了本指南。
Mohd Yuthly
于07/08/19注册
154 声望
撰写一个指南
团队
IUPUI, Team S2-G4, Harley Summer 2019 IUPUI, Team S2-G4, Harley Summer 2019 的会员
IUPUI-HARLEY-SU19S2G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 21
总计 912
