跳转到主内容
Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement
你所需要的
  1. Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement, Keyboard: 步骤 1 中的图像 1,2 Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
    • Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
  2. Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
  3. Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement, Battery: 步骤 3 中的图像 1,1
    • Put the netbook, so the back side is upwards.
  4. Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Push the right lock to the right so the red filed is visible on the left.
  5. Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
    • When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
  6. Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement, Keyboard: 步骤 6 中的图像 1,2 Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement, Keyboard: 步骤 6 中的图像 2,2
  7. Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement: 步骤 7 中的图像 1,1
  8. Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement, Remove palmrest: 步骤 8 中的图像 1,3 Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement, Remove palmrest: 步骤 8 中的图像 2,3 Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement, Remove palmrest: 步骤 8 中的图像 3,3
    • Remove the 12 screws securing the palmrest.
    • Slowly lift the palmrest up at the front, and stop when you feel the cable slack run out.
    • Remove the tape covering the connectors.
  9. Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement, Remove palmrest cables from connectors: 步骤 9 中的图像 1,1
    • Unlock the three connectors, and remove their cables.
    • Continue to lift the palmrest upwards in the front, to the point that it hinges over onto the laptop screen, so as not to pull on the remaining cable on the palmrest. You don't need to disconnect this one.
  10. Acer Aspire TimelineU M5-581T-6807 Hard Drive Replacement, Remove hard drive caddy: 步骤 10 中的图像 1,1
    • Remove the four short screws securing the hard drive caddy to the base.
    • Remove the screws securing the caddy to the hard drive. You're done!
结论
5等其他人完成本指南。
Joseph Sctbunio
于09/23/17注册
7,332 声望
创作了42篇指南
一条评论
Works very well. Just a caution on Step 2 reassembly.
Great post, thank you.
JJ Gerber - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 20
总计 2,647
