跳转到主内容
Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement
你所需要的
  1. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement, Power Button: 步骤 1 中的图像 1,2 Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement, Power Button: 步骤 1 中的图像 2,2
    • Remove the tablet from the keyboard.
    • You will not be needing the keyboard for this guide.
  2. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 2 中的图像 1,3 Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 2 中的图像 2,3 Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 2 中的图像 3,3
    • Use the opening tool to open the back cover. The opening tool should fit under the cover if you place it above the power button.
    • Lift this side of the back cover once the opening tool is inside the device.
    • Use the opening tool and your hands to gradually work around the edges of the cover.
  3. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 3 中的图像 1,2 Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 3 中的图像 2,2
    • Lift the back cover off of the device with your hands.
    • You will need to use some force to pull off the back cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 4 中的图像 1,2 Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 4 中的图像 2,2
    • Remove the piece of black, thin tape that is attached to the circuit board closest to the power button.
  5. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 5 中的图像 1,3 Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 5 中的图像 2,3 Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 5 中的图像 3,3
    • Use the opening tool to lift the ZIF connector that is holding the ribbon cable in place.
    • Pull out the ribbon cable from the circuit board. This cable should have the word "Audio" on it.
  6. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 6 中的图像 1,3 Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 6 中的图像 2,3 Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 6 中的图像 3,3
    • Use the Phillips #000 screwdriver to remove the three 3 mm screws on the circuit board.
  7. Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 7 中的图像 1,2 Acer Aspire Switch 10 SW5-012-18MY Power Button Replacement: 步骤 7 中的图像 2,2
    • Carefully remove the circuit board from the device. The power button is located on this piece.
    • To replace the power button on this piece, please go to the page How To Solder and Desolder Connections.
结论
Grecia Corrada
于03/19/18注册
1,134 声望
创作了6篇指南
团队
Baylor, Team S3-G3, Williams Spring 2018 Baylor, Team S3-G3, Williams Spring 2018 的会员
BU-WILLIAMS-S18S3G3
3 名成员
创作了6篇指南
一条评论
I have broken ZIF connector to hold power ribbon cable,can i repair this or change board?
Milan Štos - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 3,076
