跳转到主内容
Acer Aspire R5-571T-59DC Hard Drive Replacement
你所需要的
  1. Acer Aspire R5-571T-59DC Hard Drive Replacement, Back Cover Panel: 步骤 1 中的图像 1,2 Acer Aspire R5-571T-59DC Hard Drive Replacement, Back Cover Panel: 步骤 1 中的图像 2,2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: 步骤 2 中的图像 1,3 Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: 步骤 2 中的图像 2,3 Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: 步骤 2 中的图像 3,3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  4. Acer Aspire R5-571T-59DC Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Lift the hard drive up and out of the laptop.
结论
7等其他人完成本指南。
Kelly Johnston
于01/25/18注册
600 声望
创作了4篇指南
团队
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G2
3 名成员
创作了7篇指南
一条评论
I have bent the pins on my ZIF socket for my Aspire Laptop. Do you have the product name and number or know where I could buy a replacement part?
Samwise - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 4,521
