跳转到主内容
Acer Aspire R5-571T-59DC Display Replacement
你所需要的
  1. Acer Aspire R5-571T-59DC Display Replacement, Back Cover Panel: 步骤 1 中的图像 1,2 Acer Aspire R5-571T-59DC Display Replacement, Back Cover Panel: 步骤 1 中的图像 2,2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Display Replacement, Battery: 步骤 2 中的图像 1,3 Acer Aspire R5-571T-59DC Display Replacement, Battery: 步骤 2 中的图像 2,3 Acer Aspire R5-571T-59DC Display Replacement, Battery: 步骤 2 中的图像 3,3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC Display Replacement, Display: 步骤 3 中的图像 1,2 Acer Aspire R5-571T-59DC Display Replacement, Display: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, pry the back cover away from the screen.
  4. Acer Aspire R5-571T-59DC Display Replacement: 步骤 4 中的图像 1,1
    • Remove the tape covering the connector cables once the screen is separated from the display board.
  5. Acer Aspire R5-571T-59DC Display Replacement: 步骤 5 中的图像 1,2 Acer Aspire R5-571T-59DC Display Replacement: 步骤 5 中的图像 2,2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the ribbon cables out of the sockets.
结论
2等其他人完成本指南。
Star Matthew
于01/25/18注册
155 声望
撰写一个指南
团队
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G2
3 名成员
创作了7篇指南
一条评论
I wish I found this tutorial before my fiance’ attempted to do this on his own. Now the replacement screen, albeit is not cracked, but the touch screen is pretty nonfunctional in my opinion. The corners don’t really work , sometimes it picks up my touch, sometimes it goes bonkers. The bottom corner of are bent and I’m continuously having to snap them back together. I’ve bought my laptop one year ago and I feel I already need to look into another. Any suggestions to try?? any help would be super appreciated.
Christina - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 18
总计 2,038
