跳转到主内容
Acer Aspire R5-571T-59DC Motherboard Replacement
你所需要的
  1. Acer Aspire R5-571T-59DC  Motherboard Replacement, Back Cover Panel: 步骤 1 中的图像 1,2 Acer Aspire R5-571T-59DC  Motherboard Replacement, Back Cover Panel: 步骤 1 中的图像 2,2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: 步骤 2 中的图像 1,3 Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: 步骤 2 中的图像 2,3 Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: 步骤 2 中的图像 3,3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC  Motherboard Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  4. Acer Aspire R5-571T-59DC  Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift the hard drive up and out of the laptop.
  5. Acer Aspire R5-571T-59DC  Motherboard Replacement, Fan: 步骤 5 中的图像 1,1
    • Remove the seven 0.7mm Phillips #00 screws securing the fan in place.
  6. Acer Aspire R5-571T-59DC  Motherboard Replacement: 步骤 6 中的图像 1,1
    • Unplug fan from motherboard.
    • Lift and remove fan from case.
  7. Acer Aspire R5-571T-59DC  Motherboard Replacement, RAM: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Lift up the protective covering away from the RAM using tweezers, or your fingers.
  8. Acer Aspire R5-571T-59DC  Motherboard Replacement: 步骤 8 中的图像 1,3 Acer Aspire R5-571T-59DC  Motherboard Replacement: 步骤 8 中的图像 2,3 Acer Aspire R5-571T-59DC  Motherboard Replacement: 步骤 8 中的图像 3,3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
  9. Acer Aspire R5-571T-59DC  Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Remove the nine 0.7mm Phillips #00 screws from the motherboard.
  10. Acer Aspire R5-571T-59DC  Motherboard Replacement: 步骤 10 中的图像 1,1
    • Use a spudger to flip up the retaining flaps on all of the ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
    • Lift up and remove the motherboard.
结论
Kelly Johnston
于01/25/18注册
600 声望
创作了4篇指南
团队
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G2
3 名成员
创作了7篇指南
一条评论
Hi, my laptop is Acer R5-571TG-765T.
1. Does the bare bones motherboard have the same physical configuration as your R5-571T-59DC?
2. Is M.2 NVMe SSD compatible with my motherboard?
3. My laptop runs hot even with a cooling fan stand beneath. Would you recommend NVMe?
4. If heat is a problem, and availability of reputable and affordable M.2 SATA is lacking where I am -- will I be able to use a 2.5" SATA SSD as a boot drive and keep my existing 2.5" SATA HDD as a D drive at the same time?
Thank you!
availability - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 24
总计 1,922
