跳转到主内容
Acer Aspire E5-721-64T8 Hard Drive Replacement
你所需要的
  1. Acer Aspire E5-721-64T8 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8 Hard Drive Replacement: 步骤 4 中的图像 1,2 Acer Aspire E5-721-64T8 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  5. Acer Aspire E5-721-64T8 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Remove the four 3mm Phillips #0 screws from the hard drive.
  6. Acer Aspire E5-721-64T8 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the ZIF connector and remove the hard drive from the laptop.
结论
Ed Herrera
于01/25/18注册
390 声望
创作了3篇指南
团队
USF Tampa, Team S7-G3, Passmore Spring 2018 USF Tampa, Team S7-G3, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 11
总计 897
