跳转到主内容
Acer Aspire 5742G Memory stick Replacement
你所需要的
视频概述
click here for video
  1. Acer Aspire 5742G Memory stick Replacement, Memory stick: 步骤 1 中的图像 1,1
    • Make sure your computer is off and remove the battery with the security tabs shown in the picture
  2. Acer Aspire 5742G Memory stick Replacement: 步骤 2 中的图像 1,1
    • Remove these philips screws, only two :)
  3. Acer Aspire 5742G Memory stick Replacement: 步骤 3 中的图像 1,2 Acer Aspire 5742G Memory stick Replacement: 步骤 3 中的图像 2,2
    • Then from the dented tab, either your finger, card or spudger will work, and start prying GENTLY!
    • Easily work your way around.
    • WARNING! PLASTIC TABS! be careful not to break them!
  4. Acer Aspire 5742G Memory stick Replacement: 步骤 4 中的图像 1,1
    • Now you've removed the cover, you will get access to your Antenna, HDD, and RAM
    • Please remove both tabs with the memory stick at the same time
  5. Acer Aspire 5742G Memory stick Replacement: 步骤 5 中的图像 1,1
    • Now put the new memory stick in!
    • When it is in, then gently push it downwards to lock it in place!
    • Be aware you have to line up the stick with a pin in the socket!!
结论
2等其他人完成本指南。
Petter Berget
于05/12/15注册
740 声望
创作了3篇指南
团队
Kid fixers Kid fixers 的会员
Community
169 名成员
创作了225篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 800
