简介
This guide shows you how to install a new keyboard for an Acer Aspire 5100 laptop.
Before using this guide, make sure to review the Acer Aspire 5100 Trouble Shooting page.
Be sure to power off your laptop completely and disconnect from any external power source before beginning installation.
你所需要的
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Under the panel, remove the two screws that connect the keyboard to the laptop.
Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
Pull the ribbon under the keyboard to detach it from the motherboard.
Remove the keyboard.
do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
steve foss - 回复
useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
You do not need to remove the whole cover, in order to replace the keyboard.
The description for this job is right.
The switch plate cover just pops off.
Screws revealed, secure the keyboard.
Unclip the ribbon cable.
Job done
Richard -
7等其他人完成本指南。
一条评论
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
