跳转到主内容
Acer Aspire 5100 Keyboard Replacement
你所需要的
  1. Acer Aspire 5100 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Acer Aspire 5100 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 Keyboard Replacement: 步骤 2 中的图像 1,3 Acer Aspire 5100 Keyboard Replacement: 步骤 2 中的图像 2,3 Acer Aspire 5100 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
结论
7等其他人完成本指南。
Brad Rollinson
于09/29/10注册
1,113 声望
创作了7篇指南
团队
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G39
5 名成员
创作了10篇指南
1指南评论
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
Rifqi Khairur Rahman - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 13,374
