跳转到主内容
Acer AL1716 Capacitor Replacement
你所需要的
  1. Acer AL1716 Capacitor Replacement, Acer AL1716 Capacitor: 步骤 1 中的图像 1,3 Acer AL1716 Capacitor Replacement, Acer AL1716 Capacitor: 步骤 1 中的图像 2,3 Acer AL1716 Capacitor Replacement, Acer AL1716 Capacitor: 步骤 1 中的图像 3,3
    • Ensure that your monitor has been unplugged from any power source for at least 24 hours.
    • Pinch as shown, and pull towards the body to remove the cover from the stand. This will require significant force.
    • Remove the four 0.7 mm Phillips #0 screws connecting the stand to the monitor.
  2. Acer AL1716 Capacitor Replacement: 步骤 2 中的图像 1,3 Acer AL1716 Capacitor Replacement: 步骤 2 中的图像 2,3 Acer AL1716 Capacitor Replacement: 步骤 2 中的图像 3,3
    • Remove the four 0.7 mm Phillips #0 screws connecting the back panel to the monitor.
    • Remove the single 0.85 mm Phillips #0 screw from the location shown.
    • Insert the plastic opening tool into the crevice along the side, top, and bottom of the monitor.
    • Pry open the monitor by running the plastic opening tool along the crevice.
    • Lift the back panel off of the monitor as shown.
  3. Acer AL1716 Capacitor Replacement: 步骤 3 中的图像 1,3 Acer AL1716 Capacitor Replacement: 步骤 3 中的图像 2,3 Acer AL1716 Capacitor Replacement: 步骤 3 中的图像 3,3
    • Remove the two 0.7 mm Phillips #0 screws on the sides of the centerpiece motherboard cover.
    • Remove by hand the two hexagonal screws securing the digital visual interface (DVI) input.
    • The DVI is typically a blue/black connector with two built-in screw connections on either side. It is secured by hand tightening the two side screws.
    • Push the centerpiece motherboard cover toward the body to remove.
  4. Acer AL1716 Capacitor Replacement: 步骤 4 中的图像 1,2 Acer AL1716 Capacitor Replacement: 步骤 4 中的图像 2,2
    • Caution: The circuit board contains capacitors (they look like cylinders) that can shock you if they discharge. Be careful not to touch them as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Remove the three 0.7 mm Phillips #0 screws connecting the motherboard to the monitor.
    • Remove the four 0.7 mm Phillips #0 screws.
    • Use a spudger or plastic opening tool to disconnect the two red and two blue connectors by placing the tool into the crevice and lifting up the connector.
    • Ensure that your pry tool is ESD-safe.
  5. Acer AL1716 Capacitor Replacement: 步骤 5 中的图像 1,1
    • Using two fingers, disconnect the power input from the housing by pushing towards the body through the opening.
    • Remove the remaining connections by holding down the motherboard and lifting up the connections.
    • A medium level of force will be required to remove the connections.
  6. Acer AL1716 Capacitor Replacement: 步骤 6 中的图像 1,2 Acer AL1716 Capacitor Replacement: 步骤 6 中的图像 2,2
    • Examine the top of each capacitor to check capacitor life.
    • A domed top surface indicates a blown capacitor that needs to be replaced.
    • Replace necessary capacitors via soldering the old capacitor out and soldering a new capacitor in.
    • Refer to this soldering guide for 如何焊接和拆焊.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 82
总计 3,317
