跳转到主内容
Accessing Logicboard
你所需要的
  1. Accessing Logicboard, Front and Back Cover: 步骤 1 中的图像 1,2 Accessing Logicboard, Front and Back Cover: 步骤 1 中的图像 2,2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Accessing Logicboard: 步骤 2 中的图像 1,1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Accessing Logicboard: 步骤 3 中的图像 1,2 Accessing Logicboard: 步骤 3 中的图像 2,2
    • Carefully pull the back of casing away from the front.
  4. Accessing Logicboard: 步骤 4 中的图像 1,3 Accessing Logicboard: 步骤 4 中的图像 2,3 Accessing Logicboard: 步骤 4 中的图像 3,3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Accessing Logicboard: 步骤 5 中的图像 1,2 Accessing Logicboard: 步骤 5 中的图像 2,2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  6. Accessing Logicboard, Logicboard: 步骤 6 中的图像 1,2 Accessing Logicboard, Logicboard: 步骤 6 中的图像 2,2
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
  7. Accessing Logicboard: 步骤 7 中的图像 1,2 Accessing Logicboard: 步骤 7 中的图像 2,2
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
  8. Accessing Logicboard: 步骤 8 中的图像 1,1
    • Pull the cover plate off for the two power cord jacks.
  9. Accessing Logicboard: 步骤 9 中的图像 1,3 Accessing Logicboard: 步骤 9 中的图像 2,3 Accessing Logicboard: 步骤 9 中的图像 3,3
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
  10. Accessing Logicboard: 步骤 10 中的图像 1,1
    • Remove the orange tape on top of the SD cardholder.
  11. Accessing Logicboard: 步骤 11 中的图像 1,1
    • Open the battery cover.
  12. Accessing Logicboard: 步骤 12 中的图像 1,2 Accessing Logicboard: 步骤 12 中的图像 2,2
    • Lift the indicated plastic piece off.
  13. Accessing Logicboard: 步骤 13 中的图像 1,2 Accessing Logicboard: 步骤 13 中的图像 2,2
    • Remove screws indicated:
    • Two black 4.80mm Phillips #00 screws
  14. Accessing Logicboard: 步骤 14 中的图像 1,1
    • Unsolder points indicated.
    • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
  15. Accessing Logicboard: 步骤 15 中的图像 1,3 Accessing Logicboard: 步骤 15 中的图像 2,3 Accessing Logicboard: 步骤 15 中的图像 3,3
    • Carefully lift up SD cardholder to reveal logicboard.
结论
Nicole Wong
于01/30/11注册
350 声望
创作了3篇指南
团队
Cal Poly, Team 4-29, Regan Winter 2011 Cal Poly, Team 4-29, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G29
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,611
