跳转到主内容
AYL SoundFit Motherboard Replacement
你所需要的
  1. AYL SoundFit Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Motherboard Replacement: 步骤 2 中的图像 1,1
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Motherboard Replacement: 步骤 3 中的图像 1,1
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Motherboard Replacement: 步骤 4 中的图像 1,2 AYL SoundFit Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Motherboard Replacement: 步骤 6 中的图像 1,3 AYL SoundFit Motherboard Replacement: 步骤 6 中的图像 2,3 AYL SoundFit Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
结论
3等其他人完成本指南。
john
于03/10/16注册
171 声望
撰写一个指南
团队
IUPUI, Team 3-3, Harley Spring 2016 IUPUI, Team 3-3, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S3G3
4 名成员
创作了5篇指南
3条评论
Where do u get a new motherboard at?
calvinsmith522 - 回复
Anybody know where to get a motherboard?
David Whitman - 回复
Where do I get a motherboard?
David Whitman - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 1,565
