跳转到主内容
ATT EL52300 LCD Screen on Handset Replacement
你所需要的
  1. ATT EL52300 LCD Screen on Handset Replacement, Battery: 步骤 1 中的图像 1,2 ATT EL52300 LCD Screen on Handset Replacement, Battery: 步骤 1 中的图像 2,2
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 LCD Screen on Handset Replacement: 步骤 2 中的图像 1,1
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
  3. ATT EL52300 LCD Screen on Handset Replacement, Motherboard: 步骤 3 中的图像 1,2 ATT EL52300 LCD Screen on Handset Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
  4. ATT EL52300 LCD Screen on Handset Replacement: 步骤 4 中的图像 1,2 ATT EL52300 LCD Screen on Handset Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
  5. ATT EL52300 LCD Screen on Handset Replacement: 步骤 5 中的图像 1,2 ATT EL52300 LCD Screen on Handset Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
  6. ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: 步骤 6 中的图像 1,2 ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: 步骤 6 中的图像 2,2
    • The motherboard is connected to the ringer, which is clipped on to the back plate of your handset.
    • Pop off the indicated clip using a pointed tweezer.
    • With the motherboard disconnected from the back plate, turn it over so that the screen is facing you.
  7. ATT EL52300 LCD Screen on Handset Replacement: 步骤 7 中的图像 1,3 ATT EL52300 LCD Screen on Handset Replacement: 步骤 7 中的图像 2,3 ATT EL52300 LCD Screen on Handset Replacement: 步骤 7 中的图像 3,3
    • To get to the connection between the display and the motherboard, remove the casing for the display using a plastic opening tool.
    • The white casing has a hole cut into it. You are going to slide the display and the speaker through this hole.
  8. ATT EL52300 LCD Screen on Handset Replacement: 步骤 8 中的图像 1,1
    • The display has a line of soldered connections to the motherboard. These all need to be undone with a soldering tool, so the screen can be removed.
    • Please refer to the 如何焊接和拆焊 for soldering help.
结论
另外一个人完成了本指南。
Katty
于08/27/15注册
340 声望
创作了3篇指南
团队
USF Tampa, Team 1-1, Sullivan Spring 2016 USF Tampa, Team 1-1, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 603
