跳转到主内容
ATT CL2940 Speakerphone Replacement
你所需要的
  1. ATT CL2940 Speakerphone Replacement, Back Panel: 步骤 1 中的图像 1,3 ATT CL2940 Speakerphone Replacement, Back Panel: 步骤 1 中的图像 2,3 ATT CL2940 Speakerphone Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Speakerphone Replacement: 步骤 2 中的图像 1,3 ATT CL2940 Speakerphone Replacement: 步骤 2 中的图像 2,3 ATT CL2940 Speakerphone Replacement: 步骤 2 中的图像 3,3
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Speakerphone Replacement: 步骤 3 中的图像 1,1
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Speakerphone Replacement, Speakerphone: 步骤 4 中的图像 1,2 ATT CL2940 Speakerphone Replacement, Speakerphone: 步骤 4 中的图像 2,2
    • Remove the front panel of the device as shown.
  5. ATT CL2940 Speakerphone Replacement: 步骤 5 中的图像 1,3 ATT CL2940 Speakerphone Replacement: 步骤 5 中的图像 2,3 ATT CL2940 Speakerphone Replacement: 步骤 5 中的图像 3,3
    • Desolder the speakerphone with a soldering iron.
    • If you are unfamiliar with solder, check out the article on soldering and be very careful. The iron is hot!
  6. ATT CL2940 Speakerphone Replacement: 步骤 6 中的图像 1,2 ATT CL2940 Speakerphone Replacement: 步骤 6 中的图像 2,2
    • Use the soldering iron to reconnect the wires to the new speaker.
    • Place the new speaker back in place.
    • Make sure that all of the components are back in place.
终点
另外一个人完成了本指南。
团队
IUPUI, Team 1-1, Harley Spring 2016 IUPUI, Team 1-1, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S1G1
4 名成员
创作了13篇指南
一条评论
Why do all these repairs require NO PARTS to replace defective parts?
And, of course< there is no links to a place to purchase the needed parts...
rpoland - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 605
