跳转到主内容
ATT CL2940 Handset Speaker Replacement
你所需要的
  1. ATT CL2940 Handset Speaker Replacement, Handset Speaker: 步骤 1 中的图像 1,2 ATT CL2940 Handset Speaker Replacement, Handset Speaker: 步骤 1 中的图像 2,2
    • Separate the two sections of the handset by pushing them apart with the tip of the metal spudger or opening tool.
  2. ATT CL2940 Handset Speaker Replacement: 步骤 2 中的图像 1,2 ATT CL2940 Handset Speaker Replacement: 步骤 2 中的图像 2,2
    • Continue separating the two sections by using the metal spudger all the way around the edge of the handset.
  3. ATT CL2940 Handset Speaker Replacement: 步骤 3 中的图像 1,1
    • After separating the two sections of the handset, it should look as shown.
  4. ATT CL2940 Handset Speaker Replacement: 步骤 4 中的图像 1,3 ATT CL2940 Handset Speaker Replacement: 步骤 4 中的图像 2,3 ATT CL2940 Handset Speaker Replacement: 步骤 4 中的图像 3,3
    • Pull the speaker out gently to detach it from the handset. The speaker is located at the top end of the handset. It is the circular white piece with red and greed wires connected to it.
    • The speaker is attached to the handset with a slightly sticky adhesive.
  5. ATT CL2940 Handset Speaker Replacement: 步骤 5 中的图像 1,2 ATT CL2940 Handset Speaker Replacement: 步骤 5 中的图像 2,2
    • Use a soldering iron to melt the existing solder off of both the red and green wires in order to completely remove the speaker.
结论
另外一个人完成了本指南。
Noor Assaf
于02/15/16注册
306 声望
创作了2篇指南
团队
IUPUI, Team 1-1, Harley Spring 2016 IUPUI, Team 1-1, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S1G1
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 644
