跳转到主内容
ASUS ZENFONE 3 Zoom Motherboard Replacement
你所需要的
  1. ASUS ZENFONE 3 Zoom  Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 ASUS ZENFONE 3 Zoom  Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Use the sim card attachment for the screwdriver found in the IFIXIT box to remove the sim card tray from the phone.
  2. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the 3.5 mm screws on both sides of the charging port, at the bottom of the phone, using the T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 3 中的图像 1,2 ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the opening tool to separate the screen and the plastic body of the phone.
  4. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 4 中的图像 1,1
    • Utilize the PH #00 attachment to remove the 3.3 mm screws in the bracket to the top left of the battery.
  5. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 5 中的图像 1,1
    • After removing the bracket and screws, pull up on the battery from the bottom of the unit and set aside.
  6. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 6 中的图像 1,2 ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove all three screws near the top of the phone with the PH #00.
    • The top right and left screws are 3.25 mm.
    • The middle screw is 2.65 mm.
  7. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 7 中的图像 1,1
    • De-solder the single black speaker wire attached to the left side of the phone.
  8. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 8 中的图像 1,2 ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 8 中的图像 2,2
    • Use the flat-edge side of iFixIt plastic spudger to detach both the ribbon connectors off the motherboard at their connection point.
  9. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to lift up on the edges of the motherboard located above where the battery, and remove the motherboard.
  10. ASUS ZENFONE 3 Zoom  Motherboard Replacement: 步骤 10 中的图像 1,1
    • The finished product should be a motherboard with no connections to the body of the phone.
终点
另外一个人完成了本指南。
Saif Aiman
于07/08/19注册
243 声望
撰写一个指南
团队
IUPUI, Team S2-G3, Harley Summer 2019 IUPUI, Team S2-G3, Harley Summer 2019 的会员
IUPUI-HARLEY-SU19S2G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 745
