跳转到主内容
ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement
你所需要的
  1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 步骤 2 中的图像 1,2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 步骤 2 中的图像 2,2
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 步骤 3 中的图像 1,3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 步骤 3 中的图像 2,3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 步骤 3 中的图像 3,3
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 步骤 4 中的图像 1,3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 步骤 4 中的图像 2,3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 步骤 4 中的图像 3,3
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. 注意:步骤 5-6 源自标记为进行中的 指南
    ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: 步骤 5 中的图像 1,2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: 步骤 5 中的图像 2,2
    • When removing the cooling fan, carefully unplug the cable that is connected to the motherboard.
    • Once you have carefully unplugged the cable, the cooling fan should just come off with ease.
  6. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 步骤 6 中的图像 1,2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the motherboard.
    • You can now replace it with a new motherboard or perform any necessary modifications to it.
  7. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Charging Port: 步骤 7 中的图像 1,1
结论
团队
USF Tampa, Team S5-G1, Walkup Fall 2017 USF Tampa, Team S5-G1, Walkup Fall 2017 的会员
USFT-WALKUP-F17S5G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,033
