跳转到主内容
ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement
你所需要的
  1. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Bottom Cover: 步骤 1 中的图像 1,1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 2 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 2 中的图像 2,2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Disconnect the Battery: 步骤 3 中的图像 1,1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Heat Shield: 步骤 4 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Heat Shield: 步骤 4 中的图像 2,2
    • Remove the black shield covering the display connector and the heat sink.
    • You may need to use double-sided adhesive tape to resecure the shield.
  5. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Display Assembly: 步骤 5 中的图像 1,1
    • Remove the black tape securing the keyboard ribbon cable to the display connector.
    • Fold the ribbon cable the opposite way, resecuring it to the hard drive to keep it out of the way.
  6. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 6 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 6 中的图像 2,2
    • Peel off the clear tape from the motherboard display connector.
  7. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 7 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 7 中的图像 2,2
    • Position spudgers on the white tabs on either side of the connector and push evenly to unplug the display.
  8. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 8 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 8 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 8 中的图像 3,3
    • Peel off the three pieces of black tape securing the display cable to the motherboard.
    • Deroute the cable from the channel it sits in.
    • Move the cable to the side, out of the way.
  9. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 9 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 9 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 9 中的图像 3,3
    • Use a spudger to release the cables from the wifi card.
  10. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 10 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 10 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 10 中的图像 3,3
    • Lift the tapes securing the wires to the motherboard.
    • Move the wires to the side out of the way.
  11. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Disconnect the Hinges: 步骤 11 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Disconnect the Hinges: 步骤 11 中的图像 2,2
    • Remove the two screws securing the hinge on the left.
    • Pry the hinge up by hand to a 90 degree angle.
  12. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 12 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 12 中的图像 2,2
    • Remove the two screws securing the hinge on the right.
  13. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display: 步骤 13 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display: 步骤 13 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display: 步骤 13 中的图像 3,3
    • Lift the base of the laptop from the front.
    • Raise it to a 90 degree angle.
    • Slide it forward slightly to clear the hinges.
    • The display is now free.
  14. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display Retaining Screws: 步骤 14 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display Retaining Screws: 步骤 14 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display Retaining Screws: 步骤 14 中的图像 3,3
    • There are two black square plastic tabs covering the retaining screws. The tabs are fixed in place with light adhesive.
    • Using a thin blade, pry off the tabs covering the screws.
  15. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 15 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 15 中的图像 2,2
    • With a Phillips #0 screwdriver, remove the two 3.8 mm screws holding the bezel in place.
  16. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Hinge Cover: 步骤 16 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Hinge Cover: 步骤 16 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Hinge Cover: 步骤 16 中的图像 3,3
    • Grasp the hinge cover and slide it to the right. It will only move about 3mm (1/8 inch).
  17. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 17 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 17 中的图像 2,2
    • Tilt the hinge cover toward you and pull up to remove it.
    • It may catch on the parts it's covering as you remove it. If that happens, just wiggle it around until it comes free.
    • No force should be needed to remove it. You do not have to pry on it to take it out.
  18. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Release the Display Panel: 步骤 18 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Release the Display Panel: 步骤 18 中的图像 2,2
    • Slide the screen down to release the catches holding it in place.
    • It will only move about 3mm (1/8 inch) and will stop when it has moved sufficiently.
  19. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 19 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 19 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 19 中的图像 3,3
    • Lift up on the now-exposed bottom edge of the screen. Go around the edges, lifting it away from the housing. If it is still caught anywhere, remember to slide it down to free it.
    • Again, no force is needed. You do not have to pry on it to take it out. Doing so will damage the housing and/or the bezel.
    • Slide the screen out from under the hinges and remove it.
  20. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Disconnect the LCD Cable: 步骤 20 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Disconnect the LCD Cable: 步骤 20 中的图像 2,2
    • Flip the touch screen assembly over and peel the clear tape covering the LCD connector off the LCD panel.
  21. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 21 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 21 中的图像 2,2
    • Using a spudger, slide the connector out in the direction of the bottom of the screen.
  22. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Touchscreen Controller Board: 步骤 22 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Touchscreen Controller Board: 步骤 22 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Touchscreen Controller Board: 步骤 22 中的图像 3,3
    • The next few steps are easier if you rotate the display so the top of the screen is facing you.
    • Peel off the tape providing a ground point to the LCD frame.
    • Use the flat end of a spudger to flip up the latch on the right connector.
  23. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 23 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 23 中的图像 2,2
    • Use the flat end of a spudger to flip up the latch on the left connector.
  24. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 24 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 24 中的图像 2,2
    • Use fine tip tweezers to slide the right ribbon cable out of the connector.
  25. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 25 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 25 中的图像 2,2
    • Use fine tip tweezers to slide the left ribbon cable out of the connector.
  26. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 26 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 26 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 26 中的图像 3,3
    • The touchscreen board is secured to the bezel with two latches on the far side and a plastic hook on the near side.
    • Use a spudger to open the right latch while gently prying up with an opening tool or a fingernail.
    • Use a spudger to open the left latch while gently prying up with an opening tool or a fingernail.
  27. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 27 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 27 中的图像 2,2
    • Rotate the board toward you while sliding it forward slightly to free it from the bottom hook.
    • Lift the board away from the bezel and move it aside.
  28. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Microphone Board: 步骤 28 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Microphone Board: 步骤 28 中的图像 2,2
    • The microphone daughterboard is held in place by being pressed down onto a plastic pin.
    • Pry it up off the retaining pin with a plastic spudger.
  29. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Camera Board: 步骤 29 中的图像 1,2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Camera Board: 步骤 29 中的图像 2,2
    • The camera daughterboard is held in place with two latches along the top of the board and two hooks on the bottom.
    • It is seated on two plastic guide pins as well.
    • Be sure the board is fully seated on the guide pins when reassembling.
  30. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 30 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 30 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 30 中的图像 3,3
    • Slide a thin pry tool between the top of the camera board and the lip of the bezel.
    • Gently pry up on the board to free it from the latches and the guide pins it sits on.
    • Lift it up and away from the bezel and set it to the side.
  31. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Wiring Harness: 步骤 31 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Wiring Harness: 步骤 31 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Wiring Harness: 步骤 31 中的图像 3,3
    • Carefully remove the five pieces of conductive tape securing the cables to the LCD frame.
  32. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 32 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 32 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 32 中的图像 3,3
    • Deroute the wiring to the daughterboards from the front bezel.
  33. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 33 中的图像 1,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 33 中的图像 2,3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: 步骤 33 中的图像 3,3
    • Deroute the LCD cable from the display.
    • The LCD / digitizer assembly is now free.
结论
Jerry Wheeler
于03/21/22注册
57,412 声望
创作了69篇指南
团队
Oregonians Oregonians 的会员
Community
7 名成员
创作了176篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 312
