跳转到主内容
ASUS VivoBook S400C CPU Fan Replacement
你所需要的
  1. ASUS VivoBook S400C CPU Fan Replacement, Remove the Bottom Cover: 步骤 1 中的图像 1,1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C CPU Fan Replacement: 步骤 2 中的图像 1,2 ASUS VivoBook S400C CPU Fan Replacement: 步骤 2 中的图像 2,2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C CPU Fan Replacement, Disconnect the Battery: 步骤 3 中的图像 1,1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C CPU Fan Replacement, Heat Shield: 步骤 4 中的图像 1,2 ASUS VivoBook S400C CPU Fan Replacement, Heat Shield: 步骤 4 中的图像 2,2
    • Remove the black shield covering the display connector and the heat sink.
    • You may need to use double-sided adhesive tape to resecure the shield.
  5. ASUS VivoBook S400C CPU Fan Replacement, CPU Fan / Heat Sink Assembly: 步骤 5 中的图像 1,3 ASUS VivoBook S400C CPU Fan Replacement, CPU Fan / Heat Sink Assembly: 步骤 5 中的图像 2,3 ASUS VivoBook S400C CPU Fan Replacement, CPU Fan / Heat Sink Assembly: 步骤 5 中的图像 3,3
    • Unplug the fan.
    • Grasp the plug with a fingernail on either side and pull it straight out from the connector.
  6. ASUS VivoBook S400C CPU Fan Replacement, Remove the Fan and Heatsink Screws: 步骤 6 中的图像 1,1
    • Remove the two 5 mm screws securing the fan.
    • Remove the four 3 mm screws securing the heat sink.
    • Removing the screw covered by the warning label will void your warranty.
  7. ASUS VivoBook S400C CPU Fan Replacement, Remove the Fan and Heatsink: 步骤 7 中的图像 1,1
    • Lift the fan and heatsink straight up to remove it.
    • Before reassembly it is essential to clean off the old thermal paste from the processor and the heatsink and to apply new. How to apply thermal paste explains how.
  8. ASUS VivoBook S400C CPU Fan Replacement, CPU Fan: 步骤 8 中的图像 1,2 ASUS VivoBook S400C CPU Fan Replacement, CPU Fan: 步骤 8 中的图像 2,2
    • Flip the assembly over and peel off the tape wrapped around the edge of the fan.
  9. ASUS VivoBook S400C CPU Fan Replacement: 步骤 9 中的图像 1,3 ASUS VivoBook S400C CPU Fan Replacement: 步骤 9 中的图像 2,3 ASUS VivoBook S400C CPU Fan Replacement: 步骤 9 中的图像 3,3
    • Starting at one end, carefully peel off the tape securing the heatsink to the lip of the fan.
  10. ASUS VivoBook S400C CPU Fan Replacement: 步骤 10 中的图像 1,1
    • Separate the fan from the heatsink.
  11. ASUS VivoBook S400C CPU Fan Replacement, Clean the Heatsink: 步骤 11 中的图像 1,2 ASUS VivoBook S400C CPU Fan Replacement, Clean the Heatsink: 步骤 11 中的图像 2,2
    • Clean the old thermal paste off the heatsink until it is spotless.
  12. ASUS VivoBook S400C CPU Fan Replacement, Clean the CPU: 步骤 12 中的图像 1,2 ASUS VivoBook S400C CPU Fan Replacement, Clean the CPU: 步骤 12 中的图像 2,2
    • Carefully remove the old thermal paste from the CPU. It is not vital to get the old paste off the parts of the chip under the Kapton tape, but be obsessive about cleaning the silicon chip itself and the area immediately next to it.
    • Do not fail to apply new thermal paste to the processor before reinstalling the heatsink. Failure to do so could lead to overheating and the possible death of your processor.
结论
Jerry Wheeler
于03/21/22注册
57,141 声望
创作了69篇指南
团队
Oregonians Oregonians 的会员
Community
7 名成员
创作了176篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 370
