跳转到主内容
ASUS TUF Gaming FX505GT Battery Replacement
你所需要的
  1. ASUS TUF Gaming FX505GT Battery Replacement, Battery: 步骤 1 中的图像 1,2 ASUS TUF Gaming FX505GT Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Shut down the device completely by pressing the power button for about five to ten seconds, and unplug the charger.
  2. ASUS TUF Gaming FX505GT Battery Replacement: 步骤 2 中的图像 1,3 ASUS TUF Gaming FX505GT Battery Replacement: 步骤 2 中的图像 2,3 ASUS TUF Gaming FX505GT Battery Replacement: 步骤 2 中的图像 3,3
    • Gently flip the laptop so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 14 mm screws found on the bottom and the left and right sides of the laptop.
    • Remove the five 7 mm PH1 screws found on the top and middle of your device.
  3. ASUS TUF Gaming FX505GT Battery Replacement: 步骤 3 中的图像 1,2 ASUS TUF Gaming FX505GT Battery Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to pry the back panel from the laptop.
    • Work around the perimeter between the back case and the base, releasing any clips as you go.
    • Remove the back cover.
  4. ASUS TUF Gaming FX505GT Battery Replacement: 步骤 4 中的图像 1,2 ASUS TUF Gaming FX505GT Battery Replacement: 步骤 4 中的图像 2,2
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
  5. ASUS TUF Gaming FX505GT Battery Replacement: 步骤 5 中的图像 1,2 ASUS TUF Gaming FX505GT Battery Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the 7 mm screw securing the battery.
    • Carefully lift the battery out of the laptop.
结论
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide. Take your e-waste to an R2 or e-Stewards certified recycler.
Matthew Harewood
于02/07/24注册
121 声望
撰写一个指南
团队
York University, Team M-4, Allen Winter 2024 York University, Team M-4, Allen Winter 2024 的会员
YORK-ALLEN-W24SMG4
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 37
总计 87
