跳转到主内容
ASUS TUF Gaming F15 FX506L Back Cover Replacement
你所需要的
  1. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Unfasten the back cover: 步骤 1 中的图像 1,2 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Unfasten the back cover: 步骤 1 中的图像 2,2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips screwdriver to remove the 10 screws securing the back cover:
    • Seven 11.6 mm screws
    • Two 14.6 mm screws
    • One 6 mm screw
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the clips: 步骤 2 中的图像 1,2 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the clips: 步骤 2 中的图像 2,2
    • Insert an opening pick between the bottom-right corner of the back cover and the chassis, near the captive screw.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the remaining clips: 步骤 3 中的图像 1,3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the remaining clips: 步骤 3 中的图像 2,3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the remaining clips: 步骤 3 中的图像 3,3
    • Insert your opening pick again between the top-left corner of the back cover and the chassis.
    • Insert the pick at a steep angle. Pry up to release the remaining clips securing the back cover.
  4. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Remove the back cover: 步骤 4 中的图像 1,3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Remove the back cover: 步骤 4 中的图像 2,3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Lift the back cover off the chassis and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our ASUS TUF laptop answers community for help.
3等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
70,402 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,077篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 117
过去 30 天: 460
总计 7,727
