跳转到主内容
ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement
你所需要的
  1. ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    • Remove the 11 Phillips screws securing the lower case:
    • Seven 11.6 mm screws
    • Two 14.6 mm screws
    • Two 6.1 mm screws
  2. ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Release the right edge clips: 步骤 3 中的图像 1,2 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Release the right edge clips: 步骤 3 中的图像 2,2
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Release the remaining clips: 步骤 4 中的图像 1,3 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Release the remaining clips: 步骤 4 中的图像 2,3 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Release the remaining clips: 步骤 4 中的图像 3,3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement: 步骤 5 中的图像 1,3 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement: 步骤 5 中的图像 2,3 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement: 步骤 5 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  6. ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Reposition the plastic: 步骤 6 中的图像 1,2 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Reposition the plastic: 步骤 6 中的图像 2,2
    • Use your fingers to move the plastic that covers the battery connector out of the way.
    • If the plastic is not staying out of the way use a piece of tape to secure it.
  7. ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Disconnect the battery: 步骤 7 中的图像 1,3 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Disconnect the battery: 步骤 7 中的图像 2,3 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Disconnect the battery: 步骤 7 中的图像 3,3
    • Use the flat end of a spudger to push each side of the battery connector until it comes out of the socket.
  8. ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Unfasten the left SSD: 步骤 8 中的图像 1,2 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Unfasten the left SSD: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3.6 mm screw securing the left SSD and its cover.
  9. ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Remove the SSD cover: 步骤 9 中的图像 1,3 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Remove the SSD cover: 步骤 9 中的图像 2,3 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Remove the SSD cover: 步骤 9 中的图像 3,3
    • Slide the SSD cover off of the SSD by grabbing the edges near the screw indent and pulling away from the SSD.
  10. ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Remove the SSD: 步骤 10 中的图像 1,3 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Remove the SSD: 步骤 10 中的图像 2,3 ASUS TUF Gaming F15 FX506HEB-DB74 Left SSD Replacement, Remove the SSD: 步骤 10 中的图像 3,3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
结论
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our ASUS TUF answers community for help.
Spencer Day
于09/14/22注册
95,619 声望
创作了662篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,526篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 830
