简介
Use this guide to replace the lower case on your ASUS TUF Dash F15.
Before you perform this repair, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
你所需要的
Remove the 14 Phillips screws securing the lower case:
Seven 8.8 mm screws
Seven 10.1 mm screws
Use a Phillips screwdriver to loosen the captive screw.
Insert an opening pick between the lower case and the chassis on the front right edge near the captive screw.
Slide the pick along the front edge to release the clips securing the lower case.
Repeat this process along the perimeter of the lower case to release the remaining clips.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our ASUS TUF answers community for help.
2等其他人完成本指南。
