跳转到主内容
ASUS ROG Strix GL503VD-DB71 Battery Replacement
你所需要的
  1. ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: 步骤 1 中的图像 1,2 ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Start with flipping the laptop over so that the bottom side is facing up.
  2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: 步骤 2 中的图像 1,3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: 步骤 2 中的图像 2,3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the screw for the small panel with a Phillips #1 screwdriver.
    • Use your plastic opening tool to lift up the cover to remove it.
    • Remove the screw beneath the service cover with a Phillips #1 screwdriver.
  3. ASUS ROG Strix GL503VD-DB71 Battery Replacement: 步骤 3 中的图像 1,3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: 步骤 3 中的图像 2,3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the 9 screws around the perimeter of the back case with a Phillips #1 screwdriver.
    • Use a plastic opening tool to pry the back cover off of the device.
    • Remove the back cover exposing the battery.
  4. ASUS ROG Strix GL503VD-DB71 Battery Replacement: 步骤 4 中的图像 1,3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: 步骤 4 中的图像 2,3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the single screw securing the battery with a Phillips #1 screwdriver.
    • Gently pull the battery cable from its connector on the motherboard.
    • Lift up on the battery to remove it.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 83
总计 5,052
