跳转到主内容
加入维修社区 - 创建账户
ASUS Q536F Screen Replacement
你所需要的
  1. ASUS Q536F Screen Replacement, Back Panel: 步骤 1 中的图像 1,2 ASUS Q536F Screen Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Screen Replacement, Display Assembly: 步骤 2 中的图像 1,1
    • Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
  3. ASUS Q536F Screen Replacement: 步骤 3 中的图像 1,3 ASUS Q536F Screen Replacement: 步骤 3 中的图像 2,3 ASUS Q536F Screen Replacement: 步骤 3 中的图像 3,3
    • Using your fingers, unplug the two power cables connecting the display to the motherboard.
    • Remove the display assembly from the laptop.
  4. ASUS Q536F Screen Replacement, Screen: 步骤 4 中的图像 1,3 ASUS Q536F Screen Replacement, Screen: 步骤 4 中的图像 2,3 ASUS Q536F Screen Replacement, Screen: 步骤 4 中的图像 3,3
    • Potential for device damage: Beneath the screen border is a sticky adhesive. Take your time and exercise caution when removing to avoid damaging it.
    • Use an iOpener to help loosen the adhesive on the screen.
    • Gently pry the bottom right corner of the screen's border and remove the sticky screen cover.
    • Use the opening tool around the entire display to ensure you cut as much adhesive as possible.
  5. ASUS Q536F Screen Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the screen from the rest of the display.
    • The new screen should come with the sticky adhesive.
结论
Adra Ledward
于09/07/23注册
557 声望
创作了5篇指南
团队
Gateway, Team 88-8, Gonzalez Fall 2023 Gateway, Team 88-8, Gonzalez Fall 2023 的会员
GCC-GONZALEZ-F23S88G8
5 名成员
创作了6篇指南
1指南评论
I've never had to do a screen replacement but I know my way around PCs. Laptops not as much, but have done other smaller repairs. Replacing the entire screen has me quite anxious. Whats the difficulty level on that?
Acrillix Official - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 26
总计 575
