简介
One of the most vital components to any electronic device is of course, the battery. (After all, it wouldn’t run at all without this) which is why it’s important to be able to know what to do when it gets damaged or straight up broken. The following guide will teach you in simple steps what you need to do when you are replacing the battery of your ASUS Q405U. (Proceed with caution using these tools around battery because they could accidentally puncture the battery)
你所需要的
Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
2等其他人完成本指南。
一条评论
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
