跳转到主内容
ASUS Q302L Hard Drive Replacement
你所需要的
  1. ASUS Q302L Hard Drive Replacement, Back Case: 步骤 1 中的图像 1,1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Hard Drive Replacement: 步骤 2 中的图像 1,3 ASUS Q302L Hard Drive Replacement: 步骤 2 中的图像 2,3 ASUS Q302L Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Hard Drive Replacement, Battery: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Hard Drive Replacement: 步骤 5 中的图像 1,3 ASUS Q302L Hard Drive Replacement: 步骤 5 中的图像 2,3 ASUS Q302L Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Hard Drive Replacement: 步骤 6 中的图像 1,2 ASUS Q302L Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,2 ASUS Q302L Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 2,2
    • Unplug the hard drive from the connector.
    • Use a Philips #0 screwdriver to remove all four 5mm screws holding the hard drive metal mounting bracket.
  8. ASUS Q302L Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips #0 screwdriver and remove the four 5mm screws on both sides connecting the Hard Drive to the mounting bracket.
    • Remove the Hard Drive from mounting bracket.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 41
总计 1,575
