跳转到主内容
ASUS PadFone X Motherboard Replacement
你所需要的
  1. ASUS PadFone X Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 ASUS PadFone X Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Motherboard Replacement: 步骤 2 中的图像 1,2 ASUS PadFone X Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the thirteen 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Motherboard Replacement: 步骤 3 中的图像 1,2 ASUS PadFone X Motherboard Replacement: 步骤 3 中的图像 2,2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Motherboard Replacement: 步骤 4 中的图像 1,1
    • Using the plastic blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force will damage the connector.
  5. ASUS PadFone X Motherboard Replacement: 步骤 5 中的图像 1,2 ASUS PadFone X Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
  6. ASUS PadFone X Motherboard Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, pry the vibration motor connector from the motherboard.
  7. ASUS PadFone X Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force will damage the conector
  8. ASUS PadFone X Motherboard Replacement: 步骤 8 中的图像 1,1
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  9. ASUS PadFone X Motherboard Replacement: 步骤 9 中的图像 1,2 ASUS PadFone X Motherboard Replacement: 步骤 9 中的图像 2,2
    • Insert the tip of the flat head screwdriver between the panel and the metal clip then gently push down until the clip is slightly bent away from the panel.
    • Do this for all the clips holding the panel down.
    • After all clips are bent away, remove the panel.
  10. ASUS PadFone X Motherboard Replacement: 步骤 10 中的图像 1,2 ASUS PadFone X Motherboard Replacement: 步骤 10 中的图像 2,2
    • Disconnect the first connector by prying it upward using the blue plastic opening tool.
    • Disconnect the second connector by first lifting the lock then pulling the connector outward.
  11. ASUS PadFone X Motherboard Replacement: 步骤 11 中的图像 1,3 ASUS PadFone X Motherboard Replacement: 步骤 11 中的图像 2,3 ASUS PadFone X Motherboard Replacement: 步骤 11 中的图像 3,3
    • Insert the tip of the blue plastic opening tool under the motherboard and gently pry upward.
    • Work your way around until the motherboard is free.
  12. ASUS PadFone X Motherboard Replacement: 步骤 12 中的图像 1,1
    • Flip the motherboard over and locate the front facing camera.
    • Using the tweezers gently remove the black locking mechanism.
    • The black locking mechanism is very fragile and extreme care should be exercised during removal.
  13. ASUS PadFone X Motherboard Replacement: 步骤 13 中的图像 1,2 ASUS PadFone X Motherboard Replacement: 步骤 13 中的图像 2,2
    • Use the tweezers to gently pull on the connector to remove the camera.
结论
另外一个人完成了本指南。
Ryan
于05/14/12注册
223 声望
创作了2篇指南
团队
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S8G4
4 名成员
创作了5篇指南
4条评论
There is a step missing between step 10 and 11, you didn't explain how to remove the flexible connector that go's to the power/volume buttons next to the camera location on the side of the phone.
David Baxter - 回复
which I only had to gently pry up on the connector from the center of the phone out and it came right off.
David Baxter - 回复
Hey iFixits,
I have a Padfone S (international version, supposedly the same as the Padfone X sold in the states), which suffered water damage. I presume the logic board needs replacing and since there are more Padfone X's out there, thinking of buying a 'for parts' phone with say, a broken screen, and just swapping logic boards to make one working phone. Does anyone know if these logic boards for the S and X are compatible?? Thanks in advance.
Jack - 回复
I have Asus padfone 2 the phones motherboard is damaged how to use the pad
tushar.modak - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,982
