跳转到主内容
ASUS D550MA-DS01 Screen Replacement
你所需要的
  1. ASUS D550MA-DS01 Screen Replacement, Keyboard Module: 步骤 1 中的图像 1,2 ASUS D550MA-DS01 Screen Replacement, Keyboard Module: 步骤 1 中的图像 2,2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
  2. ASUS D550MA-DS01 Screen Replacement: 步骤 2 中的图像 1,1
    • Turn the laptop over and open the display.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
  3. ASUS D550MA-DS01 Screen Replacement: 步骤 3 中的图像 1,2 ASUS D550MA-DS01 Screen Replacement: 步骤 3 中的图像 2,2
    • Make sure that the entire cover has been released from the plastic clips.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
    • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
  4. ASUS D550MA-DS01 Screen Replacement: 步骤 4 中的图像 1,1
    • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
    • Disconnect the three data cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  5. ASUS D550MA-DS01 Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the fully disconnected keyboard module from the laptop.
  6. ASUS D550MA-DS01 Screen Replacement, Battery: 步骤 6 中的图像 1,2 ASUS D550MA-DS01 Screen Replacement, Battery: 步骤 6 中的图像 2,2
    • Do not use any metal tool to pry any type of battery. Doing so can puncture or short the battery, resulting in damage or injury.
    • Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
  7. ASUS D550MA-DS01 Screen Replacement: 步骤 7 中的图像 1,2 ASUS D550MA-DS01 Screen Replacement: 步骤 7 中的图像 2,2
    • Lift the battery out and remove it:
    • The battery is connected to the motherboard on the left side.
    • Use your fingertips to evenly grip the battery on the left and right sides of the battery.
    • Pull straight up to lift the battery out of its place.
    • Do not use excessive force or attempt to pry the battery with any tools. Doing so will result in damage to the laptop.
  8. ASUS D550MA-DS01 Screen Replacement, Hard Drive: 步骤 8 中的图像 1,2 ASUS D550MA-DS01 Screen Replacement, Hard Drive: 步骤 8 中的图像 2,2
    • Remove the four screws that hold the hard drive in place with the Philips #1 screwdriver.
    • There are two screws connected to the motherboard and two screws connected directly to the case.
  9. ASUS D550MA-DS01 Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the hard drive by sliding it to the right to disconnect it from the motherboard and lifting out.
    • Be sure to fully disconnect the hard drive from the motherboard to ensure that you do not damage the connectors.
    • If necessary, unscrew the old hard drive from the holster and screw the new one into the holster.
  10. ASUS D550MA-DS01 Screen Replacement, DVD Drive: 步骤 10 中的图像 1,2 ASUS D550MA-DS01 Screen Replacement, DVD Drive: 步骤 10 中的图像 2,2
    • Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
  11. ASUS D550MA-DS01 Screen Replacement: 步骤 11 中的图像 1,1
    • Slide the drive out to the right of the laptop to disconnect from the motherboard.
    • Lifting the drive straight out without sliding to the right will damage the motherboard.
  12. ASUS D550MA-DS01 Screen Replacement, Motherboard: 步骤 12 中的图像 1,2 ASUS D550MA-DS01 Screen Replacement, Motherboard: 步骤 12 中的图像 2,2
    • Remove the 9 screws from the motherboard using the Philips #1 screwdriver.
    • While unscrewing the screws, it may be helpful to use the tweezers to keep control of the screws.
  13. ASUS D550MA-DS01 Screen Replacement: 步骤 13 中的图像 1,3 ASUS D550MA-DS01 Screen Replacement: 步骤 13 中的图像 2,3 ASUS D550MA-DS01 Screen Replacement: 步骤 13 中的图像 3,3
    • Disconnect the three cables attached to the motherboard.
    • Do not pull the cables by their wires. This can lead to damage to the cables.
    • The large, black cable is connected to the screen. Carefully wiggle the cable out by gripping the black tape with your fingers.
    • There may be clear tape holding the screen connector in place.
    • The cable for the fan and speaker use similar connectors. Use the black spudger or carefully grip the sides of each connector with your fingers to slowly pull them out.
  14. ASUS D550MA-DS01 Screen Replacement: 步骤 14 中的图像 1,1
    • Pull the motherboard to the right to clear the peripheral connections of the laptop casing.
    • Lift the motherboard out of the laptop.
  15. ASUS D550MA-DS01 Screen Replacement, Screen: 步骤 15 中的图像 1,1
    • Carefully free up the black and white RF cables that are running along the laptop casing and speaker housing.
  16. ASUS D550MA-DS01 Screen Replacement: 步骤 16 中的图像 1,3 ASUS D550MA-DS01 Screen Replacement: 步骤 16 中的图像 2,3 ASUS D550MA-DS01 Screen Replacement: 步骤 16 中的图像 3,3
    • Following these next steps will remove the Screen Module Anchors. Hold the screen in place as you follow these steps to prevent the screen from dropping.
    • Unscrew the 4 screws for the Screen Module Anchors using the Philips #1 screwdriver.
    • One screw is on the left anchor while three are on the right anchor.
  17. ASUS D550MA-DS01 Screen Replacement: 步骤 17 中的图像 1,1
    • Carefully lift the screen straight up and away from the laptop base.
    • The white and black RF cables will remain attached to the screen module.
结论
Calvin Wieczorek
于09/16/15注册
409 声望
创作了3篇指南
团队
IUPUI, Team 1-2, Baechle Fall 2015 IUPUI, Team 1-2, Baechle Fall 2015 的会员
IUPUI-BAECHLE-F15S1G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,159
