跳转到主内容
APEX TM785CH Speakers Replacement
你所需要的
  1. APEX TM785CH Speakers Replacement, Back Casing: 步骤 1 中的图像 1,2 APEX TM785CH Speakers Replacement, Back Casing: 步骤 1 中的图像 2,2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Speakers Replacement, Speakers: 步骤 2 中的图像 1,3 APEX TM785CH Speakers Replacement, Speakers: 步骤 2 中的图像 2,3 APEX TM785CH Speakers Replacement, Speakers: 步骤 2 中的图像 3,3
    • The speakers are located towards the bottom left and bottom right corners of the tablet.
    • If not already done, remove the black tape holding the wires down.
    • Wedge a spudger underneath the speaker in its socket, near where the wires are connected. You can then pry out the speakers.
  3. APEX TM785CH Speakers Replacement: 步骤 3 中的图像 1,2 APEX TM785CH Speakers Replacement: 步骤 3 中的图像 2,2
    • You will need a soldering/desoldering kit to desolder the 4 leads where the speakers connect to the circuit board.
结论
Brian Graschel
于03/23/15注册
823 声望
创作了6篇指南
团队
Baylor, Team 4-1, Williams Spring 2015 Baylor, Team 4-1, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,582
