简介
If your 4Sight 9’s screen has been cracked, is not responding to touch, or has a dead backlight, use this guide to replace it.
你所需要的
Place the tablet on its side so that the two screws are facing upward.
Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
Put pressure on the connector until the clasp comes undone.
Gently pull up on electrical ribbon until it disconnects from circuit board.
7等其他人完成本指南。
