跳转到主内容
4Sight 9 Motherboard Replacement
你所需要的
  1. 4Sight 9 Motherboard Replacement, Cover: 步骤 1 中的图像 1,2 4Sight 9 Motherboard Replacement, Cover: 步骤 1 中的图像 2,2
    • Place the tablet on its side so that the two screws are facing upward.
    • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
  2. 4Sight 9 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
    • Once loosened, use your hands to separate the case from the device.
  3. 4Sight 9 Motherboard Replacement: 步骤 3 中的图像 1,2 4Sight 9 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Hold the positive and negative wires as close as possible to the speaker.
    • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
  4. 4Sight 9 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
  5. 4Sight 9 Motherboard Replacement: 步骤 5 中的图像 1,2 4Sight 9 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
    • Put pressure on the connector until the clasp comes undone.
    • Gently pull up on electrical ribbon until it disconnects from circuit board.
  6. 4Sight 9 Motherboard Replacement: 步骤 6 中的图像 1,2 4Sight 9 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the second electrical ribbon from the motherboard.
    • Use the technique for the previous ribbon.
  7. 4Sight 9 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
  8. 4Sight 9 Motherboard Replacement: 步骤 8 中的图像 1,2 4Sight 9 Motherboard Replacement: 步骤 8 中的图像 2,2
    • With fingers, grip the green Wi-Fi connector.
    • Gently pull up on connector to remove tape holding the connector in place.
  9. 4Sight 9 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Using your fingers, gently lift the motherboard.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,390
