当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
In order to remove the main brake/tail light, remove small light first. This is the same process for the main light. Using pliers grip the plastic and pull while rotating counterclockwise 30 degrees and remove the bulb from the socket.
Repeat this step to remove main bulb as well.
即将完成!
终点
